Hi Barrett, you can download this plugin with some of the support downloads, but they really hid it. Go to https://www.rossvideo.com > Learn & Support > Software Downloads > Acuity
Then click on Acuity 9.2p Software Download. Then I just downloaded the smallest file, ACU_v9.2p_NoDB_NoSP.zip. Even though the download is for Acuity, it also works for XPression and has presets for all the XPression commands in it.
Download and unzip, inside it there is a Stream Deck folder containing the plugin and a PDF that tells you about it.
It works fine, the only thing is it's Windows-only, which is odd since RossTalk is a simple protocol easily called from Javascript/Node, which is what Stream Deck uses by default. So if you want to use it from a Mac or Linux, you're out of luck.
I actually wrote my own cross-platform version for internal use at our company but I can't distribute it because it has some proprietary things in it that would be insecure to make public. But if I get time maybe I'll clean it up and post it.
- Ben
Sent: 06-24-2025 18:59
Subject: Stream Deck for Xpression
Is this plugin still available? I can't find it anywhere
Barrett Brenner
Sent: 11-22-2024 08:15
Here you go: XPression Streamdeck Plugin
(link will expire)
Sent: 11-21-2024 18:34
Do you happen to have a link to this again? I am also looking for the same thing.
Christopher Decker
Sent: 04-11-2024 15:22
https://transfer.rossvideo.com/f/8029b42e3d214904
Will work with all versions of XPression
Sent: 04-11-2024 12:14
Hello, i would like to get the same plugin for the El gato StreamDeck.
Edwin Velasquez
Graphic Designer
Teaasi
Sent: 06-15-2023 17:16
Here you go: StreamDeck XPression Plugin
(Link will expire in 3 months)
