Hi friends,
facing an issue here where if my datalinq returns as a value of 10 and above, the string compare results does not work properly. As shown in the first screenshot below, if string 1 is 8, and string 2 is 13, the material visible for greater should be 0 but it returns 1. The second screenshot shows the result properly when both values are below 10. Any way I can format out the datalinq into a value?
Gelvan Neo
Senior Production Engineer
Zenway Productions
