Trying to push data from a table to a dropdown box.
I am able to get the first row to populate but not the rest.
Any ideas?
<abs contexttype="opengear" dblinqport="2222" gridsize="20" keepalive="true">
<meta>
<lookup id="hosts">
<entry key="local.port">7788</entry>
<entry key="local.host">localhost</entry>
</lookup>
<params>
<param access="1" constrainttype="STRUCT" name="Team Info" oid="templates.teamInfo" structtype="com.rossvideo.playinfo" type="STRUCT" widget="table">
<value>
<subparam access="1" maxlength="0" name="Name" suboid="TeamName" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Number" suboid="TeamNumber" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Country" suboid="TeamCountry" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Finish Time" suboid="TeamFinish" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Split 1" suboid="TeamSplit1" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Split 2" suboid="TeamSplit2" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Split 3" suboid="TeamSplit3" type="STRING" value="Test" widget="default"/>
<subparam access="1" maxlength="0" name="Split 4" suboid="TeamSplit4" type="STRING" value="Test" widget="default"/>
</value>
</param>
<param access="1" maxlength="0" name="runClock" oid="runClock" type="STRING" value="00:00.000" widget="label"/>
<param access="1" constrainttype="INT_CHOICE" name="Confirm Prompt" oid="Confirm_Prompt" precision="0" type="INT32" value="1" widget="button-prompt">
<config key="w.changeprompt">Submit changes?</config>
<constraint key="0">Submit</constraint>
<constraint key="1">Submit</constraint>
</param>
<param access="1" maxlength="0" name="rowstyles" oid="rowstyles" type="STRING" value="bg#000011;fg#ffffff" widget="default"/>
<param access="1" constrainttype="STRUCT" name="Team Info" oid="params.teamList" structtype="com.rossvideo.teaminfo" templateoid="templates.teamInfo" type="STRUCT_ARRAY" widget="table">
<value>
<subparam suboid="TeamName" value="Name 1"/>
<subparam suboid="TeamNumber" value="1"/>
<subparam suboid="TeamCountry" value="GBR"/>
<subparam suboid="TeamFinish" value="1:02.124"/>
<subparam suboid="TeamSplit1" value="+1:56.125"/>
<subparam suboid="TeamSplit2" value=""/>
<subparam suboid="TeamSplit3" value=""/>
<subparam suboid="TeamSplit4" value=""/>
</value>
<value>
<subparam suboid="TeamName" value="Name 2"/>
<subparam suboid="TeamNumber" value="2"/>
<subparam suboid="TeamCountry" value="IRL"/>
<subparam suboid="TeamFinish" value="1:07.321"/>
<subparam suboid="TeamSplit1" value="72\"/>
</value>
<value>
<subparam suboid="TeamName" value="Name 3"/>
<subparam suboid="TeamNumber" value="3"/>
<subparam suboid="TeamFinish" value="1:06.256"/>
<subparam suboid="TeamSplit1" value=""/>
</value>
<value>
<subparam suboid="TeamName" value="Name 4"/>
<subparam suboid="TeamNumber" value="4"/>
<subparam suboid="TeamCountry" value="FRA"/>
<subparam suboid="TeamFinish" value="59.231"/>
</value>
<value>
<subparam suboid="TeamName" value="Name 5"/>
<subparam suboid="TeamNumber" value="5"/>
<subparam suboid="TeamCountry" value="AUS"/>
<subparam suboid="TeamFinish" value=""/>
</value>
<value>
<subparam suboid="TeamName" value=""/>
<subparam suboid="TeamNumber" value=""/>
<subparam suboid="TeamCountry" value=""/>
</value>
</param>
<param access="1" constrainttype="INT_CHOICE" name="NumberDropdown" oid="NumberDropdown" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">3</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="PlayerDropdown" oid="PlayerDropdown" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">Name 3</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="CountryDropdown" oid="CountryDropdown" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">GBR</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="FinishDropdown" oid="FinishDropdown" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">1:01.321</constraint>
</param>
<param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="Selection" oid="Selection" precision="0" type="INT32" value="4" widget="default"/>
<param access="1" constrainttype="INT_CHOICE" name="Dropdown" oid="params.combo" precision="0" type="INT16" value="0" widget="combo">
<constraint key="0">a</constraint>
<constraint key="1">b</constraint>
<constraint key="2">c</constraint>
<constraint key="3">d</constraint>
</param>
<param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" type="INT16" value="0" widget="table">
<constraint>params.array</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="Split1Dropdown" oid="Split1Dropdown" precision="0" type="INT16" value="0" widget="default">
</param>
</params>
</meta>
<table colspan="1" fill="both" height="540" insets="2,2,2,10" left="60" rowspan="1" style="bg#dark;bdr:round;" top="60" weightx="1.0" weighty="1.0" width="1000">
<tr>
<label colspan="2" fill="both" insets="2,2,2,2" name="Competitiors" rowspan="1" style="txt-align:west;font:bold;size:Big;" weightx="1.0" weighty="0.0"/>
</tr>
<tr>
<param colspan="7" constrainttype="STRING_CHOICE" element="0" evenstyle="f:bg#tablezebra;" fill="both" insets="2,2,2,2" oid="params.teamList" precision="0" rowspan="1" showlabel="false" style="t:bg#696969;" weightx="1.0" weighty="1.0">
<config key="w.selectionparam">Selection</config>
<config key="w.reorder">true</config>
<config key="w.padding">10,15</config>
<config key="w.colminwidth.0">250</config>
<constraint>TeamName</constraint>
<constraint>TeamNumber</constraint>
<constraint>TeamFinish</constraint>
<constraint>TeamCountry</constraint>
<constraint>TeamSplit1</constraint>
<constraint>TeamSplit2</constraint>
<constraint>TeamSplit3</constraint>
<constraint>TeamSplit4</constraint>
</param>
</tr>
</table>
<param expand="true" height="60" left="1220" oid="PlayerDropdown" precision="0" showlabel="false" style="size:Biggest;bdr:round;" top="180" widget="combo" width="260">
<task tasktype="ogscript">// Set the number to match
var player = params.getValue('PlayerDropdown', 0);
var number = params.getValue('NumberDropdown',0);
var country = params.getValue('CountryDropdown',0);
var finish = params.getValue('FinishDropdown',0);
if (player != number)
ogscript.debug('Player dropdown value, doing change to:' + player);
params.setValue('NumberDropdown', 0, player);
else
ogscript.debug('Player dropdown value, No Change:' + player);
if (player != country)
params.setValue('CountryDropdown', 0, player);
else
if (finish != country)
ogscript.debug('Number dropdown value, doing change to:' + player);
params.setValue('FinishDropdown', 0, number);
else
ogscript.debug('Number dropdown value, No change to:' + number);</task>
</param>
<param expand="true" height="60" left="1120" oid="NumberDropdown" precision="0" showlabel="false" style="bdr:round;" top="180" widget="combo" width="80">
var country = params.getValue ('CountryDropdown',0);
var finish = params.getValue ('FinishDropdown',0);
params.setValue('PlayerDropdown', 0, number);
else
if (country != number)
params.setValue('CountryDropdown', 0, number);
else
if (finish != number)
else
</param>
<param expand="true" height="40" left="1120" oid="CountryDropdown" style="bg#textbg;" top="260" widget="label" width="120"/>
<param expand="true" height="40" left="1260" oid="FinishDropdown" style="bg#textbg;" top="260" widget="label" width="140">
<task tasktype="ogscript"/>
</param>
<param colspan="2" expand="true" fill="both" height="60" insets="2,2,2,2" left="1320" oid="Confirm_Prompt" rowspan="1" style="style:toggleButton;bg#001FC1;size:Big;font:bold;txt-align:center;" top="100" width="180">
<task tasktype="ogscript">var i; // loop counter
for (i=0;i<30;i++) // Hardcoded to 30 elements in the player names
Name = params.getValue('params.teamList.TeamName', i);
Number = params.getValue('params.teamList.TeamNumber',i);
Country = params.getValue('params.teamList.TeamCountry',i);
Finish = params.getValue('params.teamList.TeamFinish',i);
Split1 = params.getValue('params.teamList.TeamSplit1',i);
// Now update the constraint
params.replaceConstraint('PlayerDropdown', constraintName);
params.replaceConstraint('NumberDropdown', constraintNumber);
params.replaceConstraint('CountryDropdown', constraintCountry);
params.replaceConstraint('FinishDropdown', constraintFinish);
params.replaceConstraint('Split1Dropdown', constraintSplit1);
ogscript.debug('Starting to Create Dropdowns');
var Names = new Array();
var Numbers = new Array();
var Country = new Array();
var Finish = new Array();
var Split1 = new Array();
var name; // Temp name value
var number; // Temp number value
var country; // Temp country value
var finish; // Temp finish value
var split1; // Temp split1 value
// Names
name = params.getValue('params.teamList.TeamName', i);
number = params.getValue('params.teamList.TeamNumber',i);
country = params.getValue('params.teamList.TeamCountry',i);
finish = params.getValue('params.teamList.TeamFinish',i);
split1 = params.getValue('params.teamList.TeamSplit1',i);
ogscript.debug('Found Player: ' + name + ' Jersey: ' + number);
// Skip this one if the value is the default value
if (name != 'Insert Name')
ogscript.debug('Adding Entry: ' + name);
Names[Names.length] = name;
Numbers[Numbers.length] = number;
Country[Country.length] =country;
Finish[Finish.length] =finish;
Split1[Split1.length] =split1;
params.replaceConstraint('NumberDropdown', params.createIntChoiceConstraint(Numbers));
params.replaceConstraint('PlayerDropdown', params.createIntChoiceConstraint(Names));
params.replaceConstraint('CountryDropdown', params.createIntChoiceConstraint(Country));
params.replaceConstraint('FinishDropdown', params.createIntChoiceConstraint(Finish));
params.replaceConstraint('Split1Dropdown', params.createIntChoiceConstraint(Split1));
ogscript.debug('Names.length:' + Names.length);</task>
</param>
<param colspan="2" expand="true" fill="both" height="60" insets="2,2,2,2" left="1120" oid="Confirm_Prompt" rowspan="1" style="style:toggleButton;bg#001FC1;size:Big;font:bold;txt-align:center;" top="100" width="180">
<task tasktype="ogscript">var newValuesName = params.getAllValues('params.teamList.TeamName');
var constraintName = params.createIntChoiceConstraint(newValuesName);
var newValuesNumber = params.getAllValues('params.teamList.TeamNumber');
var constraintNumber = params.createIntChoiceConstraint(newValuesNumber);
var newValuesCountry = params.getAllValues('params.teamList.TeamCountry');
var constraintCountry = params.createIntChoiceConstraint(newValuesCountry);
var newValuesFinish = params.getAllValues('params.teamList.TeamFinish');
var constraintFinish = params.createIntChoiceConstraint(newValuesFinish);
var newValuesSplit1 = params.getAllValues('params.teamList.TeamSplit1');
var constraintSplit1 = params.createIntChoiceConstraint(newValuesSplit1);
params.replaceConstraint('Split1Dropdown', constraintSplit1);</task>
</param>
<param expand="true" height="40" left="1420" oid="Split1Dropdown" style="bg#textbg;" top="260" widget="label" width="140">
</param>
Sam McIntosh
National Rugby League
Australia
