  • 1.  Take Offline with Visual Logic or Script
    Posted 11-02-2023 05:29
    Hello
    I made a countdown that counts down to a specific time and resets itself to 59:59 as soon as the time is reached. Is there a way to take it offline in the sequence with visual logic or a script?
    Oliver
  • 2.  RE: Take Offline with Visual Logic or Script
    Ross Staff
    Posted 11-02-2023 07:32
    Yes you can.
    One option is make a scene director with an offline event and trigger that to play once the time reaches 0 or whatever number you wish it to trigger at.
    Or you can achieve the same with script onSetText;
    dim sd as xpSceneDirector
    scene.GetSceneDirectorByName("OUT", sd)
    if text = "00:00"
    sd.play
    end if
  • 3.  RE: Take Offline with Visual Logic or Script
    Posted 11-02-2023 08:02
    Thank you very much Simon works perfectly fine now
    Oliver Frei
  • 4.  RE: Take Offline with Visual Logic or Script
    Ross Staff
    Posted 11-02-2023 08:03
    No problem :)
