  • 1.  Take scene offline when Dashboard clock reaches 00:00
    Posted 16 days ago
    Hi everyone
    I have a dashboard panel with 4 timers being used for rugby yellow card sin-bin timing.  I have a scene containing a text object that receives the clock information from Dashboard (NOT an internal XPression clock).  I am using XPression PRIME Go version 7 (don't laugh).  The clock comes on via the main scene director, with a pause, followed by a "take offline" event. So, the timer comes on, and I then need the scene director to resume (or play on) once the timer reaches 00:00.  I am struggling to get the visual logic to work. I've tried String Compare using the clocktimer text object and a string value block.  Doesn't work. I've tried various other methods, both using numeric values and string values, and have come up empty every time. I'm running out of time, so if anybody has the secret knowledge, please share?
    Here is a screenshot of my visual logic. The String Value is 00:00. Regardless of the clock's value, I'm getting a boolean of 1 all the time, even when the 2 are different.
    Ilana
    Ilana Gordon
  • 2.  RE: Take scene offline when Dashboard clock reaches 00:00
    Ross Staff
    Posted 16 days ago
    If you want to compare a string you should use "String Compare" block.
  • 3.  RE: Take scene offline when Dashboard clock reaches 00:00
    Posted 15 days ago
    That's it!  A String Compare block between the first 2 and the Equal-To block did the trick. Also, I made a separate scene director for the Dissolve-Out animation instead of using the Resume action.
    Thanks for the quick response, Simon. Much appreciated!
    Ilana Gordon
  • 4.  RE: Take scene offline when Dashboard clock reaches 00:00
    Ross Staff
    Posted 15 days ago
    No worries, pleased I was able to help!
