READ -- this will send the TAKE command to the current Item that is in Focus on the XPression Sequencer (The Blue Selection) but will not Advance the Bar.
Take Next or NEXT as usually referred to will Take the item in Focus and Move the Bar to the next line if there are no Pauses in the Scene Director.
Take (1) is a Take Command with just the TAKE ID... That will TAKE without moving the Bar the Take ID to the Channel and Layer as set in the Sequencer
Take (2) is a Take Command with the Take ID and the Channel specified ... so it ill force the take item to that channel but will still use the layer that is in the sequencer
Take(3) is a Take Command that let's you specify The TAKE ID : The Channel : The Layer (and it does not move the Focus Bar). And will change the Channel and Layer (or force them so to speak) to the channel and layer that you put in the custom control.
