Hi Robert,
In the tally console software, the source definition table is not updated dynamically - the names in the first column do not update if the name in the upstream router changes. You can however set the router to be the default source of names
If you navigate to Hardware > Com Ports > Routers and select your Evertz router, you will see two check boxes on the far right options pane (use as short namem use as long name)
When checked, this causes the tally system to send the router provided name to the multi-viewer (the name set assigned to Quartz profile 4843)
This change will need to be sent to the tally controller (CTRL+U)
This router provided name will be sent if there is no alias (long name or short name) defined in the tally system console.
If you define an alias in the tally system console, that will name overrides any name provided by Evertz
David Russell
