Yeah, I tried to re-store them, it didnt help. I also reviewed my process and confirmed that Effects Duration From Memory is a big brown box. I appreciate bug squashing is a frustrating process. I'm happy to help any way I can .. do a call, screen share dashboard... whatever I can do to assist. TD2 a lovely machine.
Sent: 05-04-2023 12:09
Subject: TD 2 display Oddness
I have forwarded this thread to the dev team.
the bug is obviously not completely fixed as they thought..
Did you restore each memory with the transition rate after the upgrade? It's the only thing I can think of that might be required.. otherwise yeah it's going to need to be looked at again.
Sent: 05-04-2023 11:58
Hi Danny,
Thank you for the update. As you know Les very well, I am sure that you know that he will be tracking 'that bug'.
Glad that the upgrade process went well though.
Raphael Samad
Business Development Manager
Production Switchers/Video Servers
Sent: 05-03-2023 18:34
Raphael,
To close the loop on this if you are tracking it, I was about to do a show so I didn't want to restart the panel. I didn't even think of running a diagnostics so thanks for mentioning that .. I'll do that next time. The "failed" buttons progressed to the ME PP row and those crosspoints didnt work at all! The LED display was black (no color) and there were no sources in those locations. I lost 2 cameras. Slight panic there. I reloaded the show file and everything came back and remained stable.
We did the TD 2.0 and Carbonite 7.1 update today, which was preplanned and that went without any problems. The upgrade process is well designed.
I'm a bit disappointed that this version of software still has the bug (?) where transition rates are not stored in memories. I sent my list to Les .. I'm sure he'll be thrilled to hear from me! :)
Sent: 05-03-2023 02:05
Hi Danny,
I know that you have a lot of experience of our products and this does sound very strange. Have you tried the control panel diagnostic test to check to see if everything is working okay on the panel? If not, then it does sound like it might be worth doing. You could also call our TechSupport@rossvideo.com Team to help you. Something this strange may suggest a control panel issue.
Raphael Samad
Sent: 05-02-2023 19:14
As the day progressed, it's now affecting the ME PP row so whatever the error is, its building up.
