  • 1.  Tessera SE and ClipStore
    Posted 03-11-2026 13:55
    Hi
    I have a Tessera SE dongle, and I don't seem to have all the Clip Store options available. Specifically the Display -> Clip Browser, which is greyed out.
    I can do the Clip Store setup under the Edit menu, and Clip Store server is running and I can access the Clip Store manger. I can also send clips to the Clip Store via the Record button, but if I can't browse the clips, how do I use it?
    There doesn't seem to be an option to set up Server Channels either, but maybe that doesn't make sense under Tessera.
    I'm currently trying this on Flex v12.7 build 6231, bit also tried it on SCE 11.5 build 5830.
    Running on Windows 10.
    Simon
    Simon Latus
    Simon Latus Media Ltd
    United Kingdom
  • 2.  RE: Tessera SE and ClipStore
    Posted 03-11-2026 16:15
    Hi Simon - are you trying to open the Clip Browser in Layout or Sequencer mode? Clip Browser can only be opened in Sequencer mode.
    Tessera enables the Clip Store/Browser & Key to Fill outputs, but it does not enable Server Channels or Media Control Gateway - those require the XPression Clip Server license.
  • 3.  RE: Tessera SE and ClipStore
    Posted 03-12-2026 06:00
    Putting it into Sequencer mode had a very positive effect!
    Can't believe I didn't think of that.
    Simon Latus
    United Kingdom
