Hi Vincent
Sorry for the delayed response. Your best option is probably to use a script table to inject HTML around your multiline text data - this will give you complete control over how it is rendered. The default renderer only uses enough width to display the data and centers additional lines within it - you can overcome this limitation by specify an absolute width.
Attached is a modified version of your panel that uses the script table with HTML wrapping:
<abs contexttype="opengear" gridsize="10" jsonport="5254" keepalive="true" touch="true">
<meta>
<params>
<param access="1" maxlength="0" name="User Name" oid="userName" type="STRING" value="Username1" widget="default"/>
<param access="1" maxlength="0" name="Chat Master" oid="chatMaster" precision="0" type="STRING_ARRAY" widget="multiline-text">
<value>Username1:
Short Text
With new Line</value>
<value>Username2:
Long Text with a lot written on the first line until the end of the box and a
short second line</value>
<value>Username1:
</value>
<value>Username1:
</value>
<value>Username1:
this
is
a
long
one
</value>
</param>
<param access="1" maxlength="0" name="User Chat" oid="userChat" type="STRING" value="" widget="multiline-text"/>
<param access="1" constrainttype="STRING_CHOICE" name="Chat Table" oid="chatTable" precision="0" type="INT16" value="1" widget="script-table">
<constraint>chatMaster</constraint>
</param>
</params>
<api immediate="true">var model = {
htmlIfy: function(str)
return '<html><body><div style="width: 800px; text-align:center">' + str.split('&').join('&amp;').split('<').join('&lt;').split('\n').join('<br/>') + '</div></html>';
getRowCount: function()
return params.getElementCount('chatMaster');
getColumnCount: function()
return 1;
getValueAt: function(row, col)
return this.htmlIfy(params.getValue('chatMaster', row) + '');
};</api>
<ogscript handles="onchange" oid="chatMaster">model.model.rowCountChanged(model.getRowCount());</ogscript>
</meta>
<table height="50" left="20" style="size:16;" top="20" width="940">
<tr>
<label anchor="east" fill="none" insets="0,0,0,5" name="Chat User Name: " style="size:16;" weightx="0.0"/>
<param anchor="west" expand="true" fill="both" oid="userName" showlabel="false" style="size:16;" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<param bottom="80" expand="true" height="90" left="20" oid="userChat" showlabel="false" style="size:16;" width="940"/>
<button bottom="20" buttontype="push" height="50" left="20" name="SEND TO CHAT" style="size:16;" width="250">
<task tasktype="ogscript">var listCount = params.getElementCount('chatMaster');
if (listCount == 1 && params.getValue('chatMaster', 0) == "") // If this is the first element and it has not been set yet
listCount = 0;
var newName = params.getValue('userName', 0);
var newChat = params.getValue('userChat', 0);
var newValue = newName + ":" + "\n" + newChat;
params.setValue('chatMaster', listCount, newValue);
params.setValue('userChat', 0, "");</task>
</button>
<param bottom="180" expand="true" left="20" oid="chatTable" showlabel="false" style="size:16;" top="80" width="940">
<config key="w.cellediting">false</config>
<config key="w.showheader">false</config>
<config key="w.padding">10,10</config>
<config key="w.model">model</config>
</param>
<button bottom="20" buttontype="push" height="50" left="720" name="CLEAR CHAT" style="size:16;" width="240">
<task tasktype="ogscript">params.setAllValues('chatMaster', ['']);</task>
</button>
James Peltzer
