James, you have my attention. How do I apply this to a current DB design?
Malcolm Thorpe
Sent: 11-02-2022 14:16
Subject: Text Input on dashboard parameter
Hi Malcolm
You might be looking for the multiline-text widget:
<abs contexttype="opengear" id="_top" keepalive="false" style=""> <meta> <params> <param access="1" maxlength="0" name="Multi-Line Text" oid="MultiLine_Text" type="STRING" value="" widget="multiline-text"/> </params> </meta> <param expand="true" height="335" left="39" oid="MultiLine_Text" scroll="vertical" top="62" width="657"/></abs>
James Peltzer
