This actually looks better than expected, let me know if this is good enough, if not I will explore a more complex solution.
Sent: 02-19-2026 04:10
Subject: Text wrap
As a workaround (not perfect) you can use a Torus and map it:
1. Create a clean scene just with you text (text shoud feet to scene width)
2. Create a new scene with a big Torus.
3. Create a new material using RenderView of Scene 1 as Shader.
4. Apply this material to the Torus
5. Edit material and adjust coordinates as you need.
Have a good day!
Gabriel Rosca
Bucharest, Romania
Sent: 02-18-2026 18:05
Subject: Text wrap
no worries! Let me know if you can figure it out. Appreciate you!
Brian Contreras
Production Coordinator
Sent: 02-18-2026 17:47
Subject: Text wrap
Ok that's the most tricky direction for xpression.
I may have a solution but it'll be a script and I need to test first. I'm not at a computer right now unfortunately but I'll have a go tomorrow.
Sent: 02-18-2026 17:35
Subject: Text wrap
I am trying to get it like this attached example with the text going from left to right
Brian Contreras
Sent: 02-18-2026 17:13
Subject: Text wrap
Depending on which direction I might have ideas.
Can you show an example of the direction you mean?
