I am currently trying to write a script that allows me to draw a passing arc for our scoring drive graphic. I receive the data in through a text box and I'm looking to use the values in those text boxes as some of the values for my lines. I get the alert stated here in the image. This was my attempt as Dim ing an integer and then having it equal the text box value but it still is not working. I don't know if applying the text box values to the coordinates of an object and then pulling those coords might work. Any help here would be greatly appreciated.
Hi Grayson.Use string below on 110
Integer.TryParse(XCordFinalNum.Text, XCordFinal)
You can also try this
XCordFinal=CInt(XCordFinalNum.Text)
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
