Infrastructure​
  • 1.  The Alexa 55 camera frequently loses sync and then locks again.
    Posted 07-23-2026 09:53
    Hello Team,
    I hope you are doing well.
    We are experiencing an issue where the camera intermittently loses sync and then locks again.
    Our setup includes two OpenGear frames with multiple DA cards. One OpenGear frame is installed in the server room, and the other is in the studio. The camera is connected to a DA card in the studio OpenGear frame, which receives its reference signal from the OpenGear frame in the server room.
    The issue occurs when the camera receives the reference through the studio OpenGear frame. However, if we connect the reference signal directly from the server room to the camera, it works normally without any sync loss.
    As part of our troubleshooting, we have already replaced both the OpenGear frame and the DA card, but the issue still persists.
    Could you please help us identify the possible root cause and suggest a solution?
    Dammer Swar
    Senior service engineer
    Global vision multimedia
  • 2.  RE: The Alexa 55 camera frequently loses sync and then locks again.
    Posted 07-23-2026 09:54
    I would recommend opening a ticket with Support.
    Director, Switcher Product Management
  • 3.  RE: The Alexa 55 camera frequently loses sync and then locks again.
    Posted 07-24-2026 01:07
    Hello Les,
    Thank you and well noted.
    best regards
    Swar Dammer bahadur
    senior service engineer
    Dammer Swar
