Hello, I have a lower third file sent to me by editors that I need to use to have it do the following in the following order:
- Animate On
- Have it loop until I animate out
- Have text (ONLY) change if I use the same scene, but with different text
I have looked at videos and tried finding help on the forum here. If anyone has accomplished this before and can provide some guidance or even a scene you have used before, that would be helpful.
What I have done is built separate scene directors for "In", "Loop", "Back to Back In", and "Back to Back Out".
"In": I dragged and dropped the avi file on the sd and trimmed it to the frame right before the start of the looping frame
"Loop": Have it starting at the loop frame and going to the end, with an Event added to tell it to jump back to the top of the loop
B2B In and Out: Are just animating the font in/out
Issue: Anytime I trigger another L3rd (which is using the exact same scene) that only has different text, it does the full animation all over again and I don't really want that, I just want the text to change.
SN: Yes, I have set up Transition Logic runs for B2B. But am still getting the same issue.
What am I missing for this not to work properly?
Danny Wright
Graphics Op
