I will love to se how.
Otherwise, if my template can work, it would be nice, i'm just not sure how to do.
Sent: 11-14-2023 09:31
Subject: ticker in one scene?
you need to use the parent group method instead of the sequence group method.
I will send you a video.
Sent: 11-14-2023 09:29
I use external data from our NRCS and use Mosart, therefore I need it in one scene only, can't use the function in XPression with ROLL/CRAWL.
Tue Sandbæk
Director / TV-Technician
TV SYD
Sent: 11-14-2023 09:24
Are you using external data or you want to be able to type into the template from sequence?
Sent: 11-14-2023 09:16
Yes, I believe so.
Tue Sandbæk
TV SYD
Sent: 11-14-2023 09:13
So it's what we would call a crawl?
Sent: 11-14-2023 08:50
I managed to make this.
But I can't get it run as I wan't.
The text has to run from left to right, start outside the picture and run all to the left until I take it off air
Tue Sandbæk
TV SYD
Sent: 11-14-2023 05:54
File > export.
However I don't really need to see the project I just need to know why type of ticker you want?
A video link to anything similar is fine.
Sent: 11-14-2023 05:52
I have my project, but how to export it so I can upload it here?
Tue Sandbæk
TV SYD
Sent: 10-23-2023 09:03
Any example of the style of ticker you want?
It should tick or crawl or roll for example?
