The extreme had a breakout unit and the time code had its own 3 pin connector. It was never part of the BB sync.
there is no other way to get LTC into the switcher frame except for serial
Sent: 11-19-2024 18:59
Subject: Time code in - Carbonite Black 113 Frame
Thank you Les.
Some years ago I were able to lock timecode to an eXtreme frame with Carbonites cards in it by inserting timecode in the BB-signal. I know that it was a bigger system then this stand alone switcher is, but do you think this frame would be able to lock to the same type of signal, and then again to the timecode?
Trond
Trond Larsen
Sent: 11-19-2024 13:19
You will need to do it 0 based and then Offset it afterwards. There are no other available Time Code to Serial Adapters.
