Hi Paulo
What are you timing/doing with your Widget timer?
If you have a widget called ClockTimer1, and put the below script in the OnSetText of the text object that is Datalinqed to your external clock source, then as soon as the external clock value changes, the widget will start.
The problem is that your widget will be 1 clock tick out, as it will start on the first change, not as soon as the clock starts, which can be different.
Do you have a flag in your Datalinq clock source that shows the clock is running? If you looked at that flag instead, that would give a more accurate result.
All depends on what your widget timer is for though!
Simon
dim myWidget as xpClockTimerWidget
'We come here when XPression is setting up the datalinq values.
'The scene may not be online though, so just reset our flag for now
'scene.tag is number that is not tied to any object, so is invisble
'and great for doing stuff like this.
if scene.IsOnline = false then
scene.tag = 0
else
'if we're here, the scene is online
'Have we been here before, ie the scene is online and the text has changed
select case scene.Tag
case 0
'first time here, so flag that
scene.tag = 1
case 1
'second time here, start our widget.
'Increment our flag so we don't try and start the widget again
engine.GetWidgetByName("ClockTimer1", myWidget)
mywidget.Start
scene.tag = 2
end select
end if
Simon Latus
Simon Latus Media Ltd
United Kingdom
