Sent: 01-09-2025 12:13
Subject: Transferring CustomPanel files onto TouchDrive Dashboard
They have been sent to you in Private Message
Sent: 01-09-2025 09:40
Ah okay. Is there a username and password associated with a local account on the TouchDrive? In order to authenticate the SCP connection?
Aaron Weston
Field Broadcast Engineer
ITN
Sent: 01-09-2025 09:11
You will need to use SCP (Secure Copy Protocol) from an application like WinSCP and connect to the panel from another PC. Then you will be able to navigate the folders to those files and delete the ones you don't want.
Dashboard does not really have the ability to Delete files.
Sent: 01-09-2025 05:07
Ah wow, can't believe we missed that! Thanks for the very helpful screenshots too.
As a follow up,do you know how I would delete a .grid file saved into the home folder? I've ended up with a bunch of test ones I can't get rid of. I've tried right clicking on them in the file navigator and clicking "remove" but they seem to re-appear after a power cycle.
Aaron Weston
ITN
Sent: 01-08-2025 16:43
My Screen Shots did not seem to transfer properly .. I will upload it as a PDF with images.
Sent: 01-08-2025 16:39
This is how you can do it with the file on a USB connected to the TD panel.
Click on File and the Open File:
Select your Drive - Then the Grid File and finally Click OK
Now with your panel Open you can Click on the File - Save As
Now Click on the dropdown in the Save UI and move to the touchdrive folder (this is like the User Documents.
Then you can Save it to that location
Note that I had already saved this to "verify" that this does work :) so in my example it looks like the file is already there ...
------OPTIONAL----------
If you wanted you could also have opted to make a Folder in this location instead of saving to the root of the user folder -- ie a DBAPP Folder to put your DashBoard Panels in..
Then we would Click to Save it here.
Now you can Close your "usb copy" that was open. We will now add the Folder Location to the File Viewer:
You now have that Folder and all of it's contents available to you for opening locally.
Remove the USB and Test :)
And there we go USB out and my Panel is now local.
