correct plug the usb into that frame then go in and use the export feature to export them.
There is no "upgrading them" The XML files and structures are different and the most efficient way that they could make a "conversion" was to implement the export feature on the Black systems. Doing an "Import" was not possible.
There is also a Simulator that can run in a VM that you can do it from.. however the most effective way is to go and export from the Frame you have.
Sent: 05-10-2024 15:28
Subject: Transferring Sets from Carbonite Black to Carbonite Ultrix
OK. So I can't just upgrade them. Need to export them from a Black frame to be used on an Ultrix frame.
Since I'm using the same USB drive from the old Black frame in the Ultrix, would those sets be accessible if I put that USB in my other Black frame that is now running v15 and export from them from there? Basically, do the sets need to be built on v15 for me to access them on a Black frame that is now running v15, if the sets were all built on a Black frame that was using v13?
Jonathan McKelvey
Director / TD
ProAngle Media
Sent: 05-10-2024 14:59
In version 15 of carbonite Black (or using the simulator for Carbonite Black) you have to "export to Ultra/Ultrix Carbonite" to use them.
they are very different and really you can pretty much just use it for Memories and Custom Controls.
There was a complete change to the underlying code base from Carbonite / Carbonite Black to the New Ultra/Ultrix Carbonite/Ultra 60 system.
