  • 1.  Transistion Logic Wildcard Question
    Posted 11-07-2022 11:44
    We have a scene that interacts directly with our lower third scene (titled "Lower Third"), but also have some lower thirds in other packages deployed via Project Server. Right now, the transition logic is looking for that scene by name "Lower Third," while the other packages have descriptors in front of it (e.g., "Election Lower Third" "Football Lower Third" etc).
    Is adding the wildcard ("*Lower Third") in front of the transition logic fields enough to work cross-pacakge, or is there a syntax I'm missing?
    Dan Jensen
    Operations Director
    WREX-TV
  • 2.  RE: Transistion Logic Wildcard Question
    Posted 01-19-2023 23:33
    Dan,
    Could you take the scene name in visual logic, feed that to a text object, and use check text object condition with the "contains" radio button selected?
    I can imagine this could be a lot of work depending upon how complex your transition logic is, so I'd understand if you keep looking for a wildcard.
    Hope this helps,
    James.
    James Hessler
    WAAY (HEARTLAND MEDIA)
  • 3.  RE: Transistion Logic Wildcard Question
    Posted 01-20-2023 04:26
    Wildcards work within a package. not sure about cross-package.
