  • 1.  Transition logic: check text object condition
    Posted 11-25-2022 09:49
    Hello everyone,
    I'm trying to build a transition logic condition which is looking at a text object on a scene which is on air.
    I've done it for B2B condition but this would be for two seperate scenes.
    Can anyone tell me if the "check text object condition" will allow me to do that?
    I'm having no luck so far although it feels it's meant to do just that. Also I'm wondering what the "check other scene" means when I hav eno way of telling which scene I want to capare my text to.
    Has anyone tried something like this?
    Nick
    Graphic Integrator | RTS
    Geneva | Switzerland
  • 2.  RE: Transition logic: check text object condition
    Posted 11-25-2022 10:19
    This scene and other scene refers to a copy of itself.
    So when you take the same scene online it looks for that text box to compare.
    I don't think it checks other scenes, only copies of itself.
  • 3.  RE: Transition logic: check text object condition
    Posted 11-25-2022 10:37
    If so, why is this condition NOT inside the B2B subfolder?
    and what is the difference with text compare which is inside the B2B subfolder?
    Nick
  • 4.  RE: Transition logic: check text object condition
    Posted 11-25-2022 10:39
    That is a valid point, I can't see a way to tell it which scene to check though, perhaps it checks scenes on the same layer?
    I did a little experiment and it only seem to do what I wanted when it was a copy of itself.
  • 5.  RE: Transition logic: check text object condition
    Posted 11-25-2022 10:20
    What do you want to achieve exactly as I may have other ideas for you.
