Thank you once again Azathoth, it worked, debug message helped, I had scene trigger in some scene directors and I also have transition logic rule, so there was a confusion there, I removed the transition logic rule and remained with the scene triggers in the scene directors and it solved everything.
LOETO
Sent: 04-16-2024 07:01
Subject: TRANSITION LOGIC PROBLEM
Thank you Azathoth, I will check on your suggestions.
LOETO
Sent: 04-15-2024 17:08
Duplicate the problem in the Sequencer and open the debug window.
Watch for the decision making in the debug window and see what rules it matched on the IN and OUT.
Then go back over your transition rules.
I have had some transition problems and realized that sometimes I had to add to a transition rule with negatives, or make another transition rule that played the same director as another rule but would guarantee being chosen over the wrong one.
Check the order of your rules too.
I believe the debug window can shed some light on your problem.
Azathoth
Son of Cthulhu
Sent: 04-15-2024 13:38
Any idea of what could be the problem?
LOETO
