Hi all,
Did anyone tried exporting clip with two channels of audio from Tria as .mxf to play it back in VLC? We run into a curious case where VLC was seeing these two channels as separate tracks and it would play only first track as mono by default. VLC can be selected to play either Track 1 or Track 2, but not both at the same time, unless it's started from command line with special options. What I did was to run the exported file through ffmpeg to merge two mono tracks into one stereo track. More details can be found on
Trouble with Tria ... playing with ffmpeg if anyone from Tria team is interested to look into it.
My question is - can clip be exported natively in Tria to .mxf with stereo track instead of two mono tracks?
Thanks,
Goran
Goran Poprzen
Broadcast Tech
SAIT
Canada
