Tria not importing opacity/RGB Luminence correctly?
  • 1.  Tria not importing opacity/RGB Luminence correctly?
    Posted 02-13-2024 13:09
    I have a transition that was given to me by a graphic artist, .mov with alpha layer that has a bit of a smoke effect. When I import it to Tria the clip ends up having a dithery look to it, almost like it imported wrong. We tried the import settings on both RGB Luminence options as well as both FFMPEG and Quicktime settings, nothing seems to make a difference. It worked fine when used as a targa sequence in our Carbonite, so we're not quite sure why it's not getting into Tria. Any ideas?
    Daniel Tompos
