Hello!
I am trying to build a custom dashboard panel for a high school to control 3 channels (2 playback, 1 record) of a Tria server. Using the Explorer template, I was able to get record and regular playback working without issue. However, we would like to be able to build a playlist within this Dashboard so our students do not have to keep searching the Clip Library every time they are loading up a new clip. Instead, they'd be able to select the clips needed during pre-production, choose which channel they will play them back from, and put them in a playlist so it is much easier to go between clips while the show is going on. These playlists do not have to be big, no more than 5 clips at a time would work. What would the best way to go about this be?
Thank you!
AJ AJ Keenan
Mobile Unit Engineer
NEP
