Hi Matthew,
Thanks for the clarification.
I have verified what you mentioned that DB shows striped TC as opposed to LTC. I have opened a case for the dev team, but due to resources, not sure when this be on the list of things to be worked on and the option be added.
Also, I will look into if showing a semi-valid TC is possible when the file is growing.
Thanks,
Bez.
Bez Zahedi
