under project shortcuts you can add a script and then use a GPI fire it.
Sent: 04-24-2023 18:12
Subject: Trigger "Disable Item" from DashBoard
Can someone explain where/how to make this happen from start to finish? Do I need to add this script to the GPI Mapping menu somehow? Ultimately, I'd like to have a dashboard button to disable and enable a specific take ID via the scheduler.
Chris Simonson
Sent: 08-30-2022 14:19
This worked, thank you!
Jarod Valentin
Sent: 08-22-2022 05:48
Try,
takeitem.Disabled = true
Sent: 08-17-2022 14:13
For the "takeitem.Disabled" do I need to set boolean values? The way I see what you put is that it should just disable the identified take item from the line above it. I got it to compile/run a Public Method(cue,execute,setfocus), but it won't compile/run "Disabled"?
Jarod Valentin
Sent: 08-16-2022 15:39
dim takeitem as xpTakeItem
engine.Sequencer.GetTakeItemByID(1, takeitem)
takeitem.Disabled
