You can script a group to pause, and trigger that script either from the same In and Out scene directors in your scene Y, or from a keyboard shortcut.
Add this to your script event in either location:
dim group as xpTakeItemGroup
engine.sequencer.getgroupbyname("Group 1",group)
group.Pause
and then to resume the group, use this:
group.Resume
Jeff Mayer
Sent: 11-18-2022 12:27
Subject: Trigger Pause/Resume Group From A Scene
Jeff, thank you so much. Worked like a charm. I made one modification to the trigger. Scene-X is designed to air for 12 seconds. The "play" trigger in the out of Scene-Y would resume Scene-X where it was interrupted. So if I triggered Scene-Y 10 seconds into Scene-X, Scene-X would continue for just 2 seconds after Scene-Y played out. So instead of "play", I triggered "play range" and set the range for a frame rate of 10 seconds so no matter where in the Scene-X playout I triggered Scene-Y, Scene X would continue for 10 seconds on the other side of Scene-Y.
Still wish there was a way to trigger a pause to the whole group so I could interrupt the playlist anywhere without adding specific triggers for every different scene in the playlist. Right now there's only 3 variants, but there could always be more.
Greg Petronzio
Graphics Op/Integrator
Freelance
Sent: 11-18-2022 06:42
Greg,
Sounds like you might be triggering a separate scene director in Scene X that has a Pause event to Play form Scene Y, rather than the scene director that's playing out and ultimately controlling the Take Item's timing in your loop group.
Instead, try to set your Scene Director Trigger (on your In SD in Scene Y) to Pause the main scene director in Scene X. Then on the Out SD on Scene Y, set the Scene Director Trigger to play the main scene director in Scene X again.
Scene Y In Scene Director:
Scene Y Out Scene Director
Jeff Mayer
