  • 1.  Triggering a Router Salvo from Dashboard
    Posted 06-16-2022 14:56
    I was wondering if there was a way to trigger a Salvo, in this instance the Salvos we have to turn our board "on" and "off", with a Dashboard button?
    I wasn't sure if a GPI trigger would work, I tried adding the Router to the Dashboard like you would an Xpression or Clips Player with no luck.
    Thank you!
    Alexa McGlade
    Live Event Producer
    UCF
  • 2.  RE: Triggering a Router Salvo from Dashboard
    Posted 06-20-2022 15:56
    Hi Alexa
    The easiest way to trigger a salvo in a router is with the RossTalk GPI message. You can send "GPI" followed by a space and the salvo number to the router's IP on port 7788.
    James
    James Peltzer
