Trying to diagnose an issue, is there a log for the Carbonite
  • 1.  Trying to diagnose an issue, is there a log for the Carbonite
    Posted 06-22-2026 12:10
    I have an issue with automation that presents like this...
    If a user sets the transition type on the Carbonite surface or the Carbonite Dashboard that's connected to the surface cueing the automation will have the wrong transition type on the first element (repeating the last transition set by the user), but successive elements are normal and work correctly.
    If I use Dashboard on my laptop to set a transition the automation cue command sets the transition to the type expected every time.
    I wanted to look at the logs to see how the Carbonite sees the commands for clues as to why this is occurring.
    Where would they be located?  Would they be any help?
    David Knighton
    Engineer
    NCSC
