Connectivity
  • 1.  TSL communication between Ultrix FR5 and Panasonic UCU 600
    Posted 06-08-2026 06:16
    I got a FR5 with Ultrix Acuity and Panasonic UCU 600 CCUs.
    Until now the tallys are feeded to the CCU with contact closurure (Sub D output of a SDPE blade)
    Tally is well working on the switcher and on ultriscape.
    I would like to switch to TSL. On my CCU I see that in the menu I can setup an ID and the port is 62000.
    On my ultrix I see that there is a TSL server runing with the router IP on port 4492.
    Could you please tell me how to make the TSL be send form the ultrix to my CCUs (I have sevral CCUs each with a specific IP and TSL ID)
    Best
    Boris salhaji
    EIC
    France Télévisions
  • 2.  RE: TSL communication between Ultrix FR5 and Panasonic UCU 600
    Posted 06-09-2026 08:57
    The Ultrix TSL Output is for sending Labels only.
    This is how external Carbonite Switchers and Graphite are able to be "told" what sources are on the outputs being routed to them.
    There is not Tally state of the source being on air carried via that connection.
    If you would like to have a Tally Control system then that will need to add Ultritally to your system and it would be calculating the tally state and then providing the solution to the endpoints.
    https://www.rossvideo.com/products/routing-systems/ultricore-tally/
    Director, Switcher Product Management
  • 3.  RE: TSL communication between Ultrix FR5 and Panasonic UCU 600
    Posted 06-11-2026 01:16
    Hi Boris, you should be sending the TSL tally from the Acuity SDPE Blade. We did this in our truck with a Carbonite SDPE Blade.
    On the 'devices' tab, you make a device for each CCU and the point the IP address to the UCU600.
    There are some good screenshots here from the Carbonite Routed Tallies setup: https://help.rossvideo.com/ultrix-carbonite/Tasks/Setup/Ultrix/Tallies/To-Ultrix-Tallies_switcher.html
    Acuity information here: https://help.rossvideo.com/acuity-device/Topics/Devices/UMD/TSL.html#topic.tsl-protocol
    Jeremy Koch
    Director & Broadcast Engineer
    Innovative Production Services & Sports Entertainement Network
    Sydney Australia
  • 4.  RE: TSL communication between Ultrix FR5 and Panasonic UCU 600
    Posted 06-11-2026 03:13
    HI Jeremy !
    Thanks for the reply !
    Actually, there was 2 parallel thread in the forum so Les O'reily respond on the other discussion with very good informations to make it works... And so It works Fine!
    Thanks again this forum and its community really rocks !
    Best
    Boris salhaji
    EIC
    France Télévisions
  • 5.  RE: TSL communication between Ultrix FR5 and Panasonic UCU 600
    Posted 06-15-2026 08:50
    Ah copy. No problems and happy broadcasting :)
    See you around the forum!
    Jeremy Koch
    Innovative People
    Melbourne Australia
