To validate that the PC is getting Tally you could setup a Tally Service in DashBoard to verify the updates.
Add another TSL connection in your Devices
Now go to production mode and you can see if the Tally data is updating into that PC
If not then you should look at firewall settings.
If you are seeing this then it leads to be something in the companion software and would recommend following up with Bitfocus as to what the issue might be. There has been times in the past like with their RossTalk module where updates have prevented some modules from working and those modules needed updating to resolve it.
