Hey Chris,
I just tested with Quad and it will work if you use xpQuadObject instead of BaseObject. BaseObject doesn't have a DL property it looks like.
Flint Gleeson
Technical Support Product Prime - Xpression
Sent: 03-24-2025 06:46
Subject: Turn off Datalinq Live Update in the timeline
Thanks! Is it possible to turn off a Datalinqed material source on a quad as well?
The datalinq options did not appear on xpbaseobjects.
Chris Nicolay Wernersen
Sent: 03-20-2025 16:12
This should do it if you add to a script event in the Scene Director
dim mytext as xpTextObject
scene.GetObjectByName("Text1", mytext)
mytext.Datalinq.LiveUpdate=False
I will note that while the property is changing, the template data of the Take Item does not seem to reflect that.
Flint Gleeson
Sent: 03-20-2025 09:51
Or without copying the text from one text object to another, thus it won't update. I'd rather not have two text objects for every single text.
