Hi-
Is there a way to turn published items off based on a number selection? For example, if you have a template that goes up to x5 headshots and you select x2, the fields for x3-x5 turn off. By turn off, I mean these fields go invisible in the template so that the user does not get confused. I know the newer version of XPN does but I'm currently working in v10.
Thank you!
Jessica King
