Below is the source code for a very simple DashBoard I thought I'd slap together fairly easy... But appreantly not?
I've use the params.getElementCount so many times in previous DashBoards, but that was mainly for Struct Tables, but I figured since the description in the help documentation says "Get the number of elements in a parameter array" it should be no different... But appereantly I was wrong.
If you take the code below, and then use the button that says "How many presets", you will get 1 in the debug field... Not the expected 60...
Anyone that could share some insight into why?
Edit: I've gotten as far as to know that it works with a simple array, but not a choice constraint array... So how would it work with a choice constraint array?
<abs contexttype="opengear" dblinqport="2255" gridsize="10" id="_top" keepalive="false"><meta><params><param access="1" maxlength="0" name="superJoyIP" oid="superJoyIP" type="STRING" value="127.0.0.1" widget="text"/><param access="1" constrainttype="INT_CHOICE" name="mode" oid="mode" precision="0" type="INT32" value="0" widget="radio-toggle"><constraint key="0">Recall</constraint><constraint key="1">Rename</constraint></param><param access="1" constrainttype="INT_CHOICE" name="camerapresets" oid="cameraPresets1" precision="0" type="INT16_ARRAY" value="-1" widget="radio-toggle"><constraint key="1">test1</constraint><constraint key="2">test2</constraint><constraint key="3">test3</constraint><constraint key="4">test4</constraint><constraint key="5">test5</constraint><constraint key="6">test6</constraint><constraint key="7">test7</constraint><constraint key="8">test8</constraint><constraint key="9">test9</constraint><constraint key="10">test10</constraint><constraint key="11">test11</constraint><constraint key="12">test12</constraint><constraint key="13">test13</constraint><constraint key="14">test14</constraint><constraint key="15">test15</constraint><constraint key="16">test16</constraint><constraint key="17">test17</constraint><constraint key="18">test18</constraint><constraint key="19">test19</constraint><constraint key="20">test20</constraint><constraint key="21">test21</constraint><constraint key="22">test22</constraint><constraint key="23">test23</constraint><constraint key="24">test24</constraint><constraint key="25">test25</constraint><constraint key="26">test26</constraint><constraint key="27">test27</constraint><constraint key="28">test28</constraint><constraint key="29">test29</constraint><constraint key="30">test30</constraint><constraint key="31">test31</constraint><constraint key="32">test32</constraint><constraint key="33">test33</constraint><constraint key="34">test34</constraint><constraint key="35">test35</constraint><constraint key="36">test36</constraint><constraint key="37">test37</constraint><constraint key="38">test38</constraint><constraint key="39">test39</constraint><constraint key="40">test40</constraint><constraint key="41">test41</constraint><constraint key="42">test42</constraint><constraint key="43">test43</constraint><constraint key="44">test44</constraint><constraint key="45">test45</constraint><constraint key="46">test46</constraint><constraint key="47">test47</constraint><constraint key="48">test48</constraint><constraint key="49">test49</constraint><constraint key="50">test50</constraint><constraint key="50">test51</constraint><constraint key="50">test52</constraint><constraint key="50">test53</constraint><constraint key="50">test54</constraint><constraint key="50">test55</constraint><constraint key="50">test56</constraint><constraint key="50">test57</constraint><constraint key="50">test58</constraint><constraint key="50">test59</constraint><constraint key="50">test60</constraint></param></params></meta><simplegrid cols="6" height="760" hspace="2" left="100" rows="10" top="160" vspace="2" width="810"><param expand="true" oid="cameraPresets1" style="style:toggleButton;" widget="radio-toggle"><task tasktype="ogscript">function presetRecall(group, camId, preset) {var ip = params.getValue('superJoyIP', 0);var url = 'http://' + ip + '/cgi-bin/joyctrl.cgi?f=directpresets&action=recall&group=' + group + '&camid=' + camId + '&preset=' + preset + '&presetspeed=24'ogscript.debug(url);}var x = params.getValue('cameraPresets1', 0);var mode = params.getValueAsString('mode', 0);if(x != -1) {if(mode == 'Recall') {//If set to recall, do this...var x = params.getValue('cameraPresets1', 0);var text = params.getValueAsString('cameraPresets1', 0);var camId = 1;var group = 1;presetRecall(group, camId, x);params.setValue('cameraPresets1', 0, -1);} else if (mode == 'Rename') {//If set to rename, do this function somehow...}//IF SET TO RENAME}</task></param></simplegrid><param expand="true" height="40" left="450" oid="superJoyIP" top="30" width="270"/><param expand="true" height="30" left="760" oid="mode" style="style:toggleButton" top="40" width="240"/><simplegrid cols="6" hspace="2" left="950" rows="10" top="490" vspace="2"/><button buttontype="push" height="60" left="980" name="How many presets?" top="360" width="190"><task tasktype="ogscript">ogscript.debug(params.getElementCount('cameraPresets1'));</task></button></abs>------------------------------
Aleksander Stalsberg
Norway
