Hi Mike
Found your post while trying to get alias working in Ultrascape. I'm running Ultrix v6.3.0. I've created an Alias Set and assigned the Ultriscape Head to use that alias set, but it doesn't seem to work. nothing immediately changes on the Multiview once applied. However, If I route a different source to a PIP, the alias name appears for a brief moment then the UMD just reverts back to the default source name.
Any idea what may be causing this?
Thank you,
Eric
Studio Production Engineer
Eric Garabrant
Studio Engineer
COok Medical
Sent: 11-06-2024 10:09
Subject: Ultriscape Aliases
Hi Jason
Thanks for your question
Yes with the release of 6.2 the alias names are available on ultriscape.
You can select the alias field in the dropdown menu of the head selection tab. Any alias groups you create will apear here.
Mike Pomerleau
