I ran some tests with Companion 3.4.3 and Ultrix Version 6.2
I can confirm that the following rosstalk commands do the following on my stopwatch that is using ID 2
TIMER 02:RUN
Starts the Stopwatch from 00:00:00 and after being paused continues from the value where it was.
TIMER 02:PAUSE
Pauses the Stopwatch.
TIMER 02:STOP
Stops and Resets the Stopwatch.
Ill try again at V5.3.1 tomorrow.
Mike Pomerleau
Sent: 10-30-2024 12:59
Subject: Ultriscape Clocks control.
Hi Mike,
we are curently runing V 5.3.1 but I'm looking forward to upgrade to V6.2...
regards,
Boris
Boris salhaji
EIC
France Télévisions
Sent: 10-30-2024 11:34
Hi Boris,
Before I run some tests can you tell me which version of Ultrix you are using?
Mike Pomerleau
