Hello Jonathan,
You can double click the element you added, override the constraint for the parameter, and delete any sources you don't need.
Then make sure the simple grid is set to 1 row.
Let me know if this helps!
Taylor Shane
Senior Demo & Training Product Specialist - Prime, DashBoard
M: +1 (682) 800-7115
Ross Video | Let's make it real
Visit us at rossvideo.com
Sent: 04-13-2026 14:22
Subject: Ultritouch HR and Ultrix Carbonite Blade
Thanks James,
This seems close but still not quite working for me. When I attempt to paste a button from within the live assist busses menu it paste the entire group of inputs and not the specific one I copied.
I have attached a screenshot for reference. I am attempting to create a 1x5 grid filled with buttons I can then paste cameras 1-4 and black into. In image attached I have only pasted once, in this case I copied cam 1 (physical input 1) and then pasted to the first button of the created grid.
Thanks much for your help! I have on another tab created custom controls that do all the things I need but would rather this work if possible.
Jonathan Nelson
Systems Admin
Grace Church
Eden Priare United States
Sent: 04-13-2026 09:31
There are several places where you can grab controls for a Carbonite. If you want to keep the buttons from a specific ME visible, you should grab the controls from the "Buses" tab of "Live Assist".
James Peltzer
