  • 1.  Ultrix Acuity Connected to Xpression
    Posted 04-24-2026 01:37
    I have an Ultrix Acuity and an Xpression. I would like to remote control the Xpression through my Ultrix Acuity... So far it seems simple...
    Into Acuity I configured the CG but I can't get the controls into Acuity in the CG menu... But if I send a rosstalk command via a CC it works... I probably missed something.. Any Idea? I looked into the manual but it didn't help me to make it works properly... Is there a tutorial to configure it?
    Thanks !
    Boris salhaji
    EIC
    France Télévisions
  • 2.  RE: Ultrix Acuity Connected to Xpression
    Posted 04-25-2026 00:30
    the "CG" device type is meant for using the CII Gateway and is more for use with mos graphics where you want to control it via overdrive prior to caprica.
    Generally with XPression we use the RossTalk interface and you build the Custom Controls you need to control the Sequencer and take items you want to trigger.
    Director, Switcher Product Management
