  • 1.  Ultrix Acuity Tallys
    Posted 04-24-2026 01:44
    With my Ultrix Acuity the ME3 is my main program. i get the tallys on the ultriscape red and green and yellow when it is simultaneously on PGM and PVW.
    I would like to keep this behavior but I want to add a tally for ME1 PGM and PVW so that I can get on the MV the tally for these 2 ME. And if I could get different colors It would be wonderfull !
    I tried to configure the tally menu on Acuity setup>installation>sources>tallys and activate tally for ME1 choosing ME1 PGM for sources but i didn't work... I probably miss something...
    Anyone could give me a tip?
    cheers
    Boris salhaji
    EIC
    France Télévisions
  • 2.  RE: Ultrix Acuity Tallys
    Posted 04-25-2026 00:28
    in the Tally menu you can enable additional Tally calculation paths.
    https://help.rossvideo.com/ultrix-acuity/Tasks/Setup/Video/Input/To-Tally-Output.html
    Then from there you can setup on the com port sending out TSL v5 how the bits are to be used for the different Tally Paths.
    https://help.rossvideo.com/ultrix-acuity/Topics/Devices/Common/EO-SerialTally.html
    The Ultriscape does not have additional Colours though.  So you can only have the Red / Green and Amber.
    To derived additional Tally and bits you will need to use a Tally system like UltriTally that will create multiple calculations if you need to those to be separate but again at this time you can not apply additional tally colours like Yellow / Purple / Blue etc.
    Director, Switcher Product Management
