HI,
Just to sum up the setup : We are operating a Ultix Acuity (FR5 with 3 SDPE). Panel is a TD2S and we are using Ultriscape to display sources and ME outputs (basicly Cams and PGM)
I recently have a feedback of an operator saying that there is a latency between the press of a PGM button and what we see on the Ultriscape. I mean when cutting on PGM like switching from a cam to another he noticed that there is a delay on the MV.
Ok I assume that it's normal to have some kind of latency as we are producing in UHD 2160P25 and the MV is downscaled to HD so there is delay due to processing, and of course there is the delay of the screen and the HDMI converter...
When placing a SDI monitor ( sony PVM X1800) There is no delay between the press of a PGM button and the actual switching. So it indicates that the delay comes from the Ultriscape.
but to optimize my workflow do you have the exact datas about latency between switching on a Touch Drive panel and the ultriscape restitution regarding specific configuration ? (in HD, UHD 25P or 50P etc..)
Best regards
Boris salhaji
EIC
France Télévisions
