Sent: 6/13/2024 4:06:00 PM
Subject: RE: Ultrix Carbonite - routing ClipPlayer audio
Don't type anything into the Top bar .. click the X and then just use the Drop down like I did ...
Do you see it that way?
You may need to build a new database .. At this point we are getting further away from my Ultrix-Fu and we might need to contact Tech Support so that they can get an Ultrix specialist to help out.
Sent: 06-13-2024 16:03
Subject: Ultrix Carbonite - routing ClipPlayer audio
Thank you Les for bearing with me on this.
Perhaps when i created the database, i didn't it properly, becuase where you see..
I dont see AUDIO on my slot8.AUXA port... I only see a single SDI channel
Do I need to do something to create the AUDIO channels? Or, do I need to redo my entire database?
Darryl Quinn
Video Director
Woodlands Church
Sent: 06-13-2024 13:51
Slot A and B are not Virtual ports with the SDPE Blade.
There are 18 Destination Links and 18 Source links in an Ultrix Slot. Aux Port A and B are the 17th and 18th input to the blade (Router Destination) and Carbonite Outputs 17 and 18 are the Aux A and B SOURCEs in the Router. Carbonite Inputs 19-22 are the Blade Edge inputs and Carbonite Outputs 19-22 are the Card Edge Outputs.
Audio from the SDPE is Sent on AUX A ports 1-6 as you see in your original Sources Table.
When I sort on my sources (the Ultrix I have access to is an FR2 with the SDPE in the Top Slot which is Slot 1)
I click on the drop down to sort for that Slot and the audio channels
The Database builder built this to have those 6 audio sources on the physical device Aux A ports.
Mono Audio would be setup with Child sources like this so you could map and channel to any channel
You need to either Add Child Sources so that you can put Media 1 L, Media 1 R, Media 2 L, Media 2 R , Clip L and Clip R as those mono channels that are seen above as SRC 17 CH1 (SRC 17 is AUX A from Slot 1). That way you only route on Level 1 but you have to make a route per channel not as a Stereo pair would be.
You can see that the channel shows up in Every Level .. that way on a Destination you could route Channel 1 from Src 17 Input into an Destination Level 6 which would be the 6th channel of the embedded stream.
On the Destination Side of things since you have the MADI setup on a single Level as 64 Mono channels then there is no way to route TO it from Level 2-6.. Which is fine. Just Add the Child sources so that there is a separate Source for each of the 6 audio channels from the SDPE and route them to the MADI via those sources.
Sent: 06-13-2024 11:47
Maybe I should backup... here is the frame config...
slot8.AUXA and slot8.AUXB are virtual ports, correct? (because the only physical are inputs 1-4 and outputs 1-4)
when i look at the available Matrix outputs list on the Sources panel in Dashboard, the only matrix inputs for slot8.AUXA is an SDI input. I dont see audio inputs.
Darryl Quinn
Video Director
Woodlands Church
Sent: 06-12-2024 17:14
ok. Thanks Les. one thing is fixed. My "MADI *" destinations where assigned to slot1.AUXB instead of slot2.AUXB.
I changed those.
Still getting the Breakaway error when i attempt to route the SW1-ClipPlay to any destination.
Darryl Quinn
Video Director
Woodlands Church
