Dear Mike,
We are running the ULTRIX 6.4.1 Version on the HDX I/O cards. We have done the following test:
On the input 1, we have inserted a SDI Feed SOURCE with 4 Embedded Audios.
We have configured the one multiview and on Settings for Alarms we have set active the Video VIDEO LOS; Video FREEZE and on AUDIO we have set Audio LOS and Audio SILENCE.
Nevertheless we have noticed although the audio is running on Channel 1 & 2, the display on the Multiview is showing SILENCE. (Hysteresis = 10 sec)
First TEST : remove the SDI cable Status: VIDEO LOS AUDIO LOS on MVW
Second TEST : STILL FRAME on SDI cable No Audio Status: VIDEO FREEZE on MVW
Third TEST : SDI cable IN // AUDIO OFF on all CHANNEL Status: no AUDIO LOS showing on MVW
Fourth TEST: SDI cable IN // AUDIO 3+4 OFF Status: no AUDIO LOS showing on MVW
Fifth TEST: SDI cable IN // AUDIO 1+2 OFF Status: no AUDIO LOS showing on MVW
SDI Cable running audio 1 + 2 only Status: AUDIO SILENCE showing on MVW SEE Attachment
Your kind advice is highly appreciated.
Satellite Officer
(Technology & Infrastructure Support)
Technology Dept
E-mail : d.bholah@mbcradio.tv
Office : (+230) 4028099 Ext: 501
https://mbcradio.tv/ :
Mauritius Broadcasting Corporation
Royal Road, Moka. (80812) MRU
+230 402800
Sent: 5/1/2025 1:03:00 PM
Subject: RE: Ultrix FR12
Hi
Can you tell me what version of Software you are running and which type of card you are using for the input in question?
I can run some tests.
Mike Pomerleau
