Hi Bholah,
It is not possible to customize the background colors for the Ultrix soft panels directly. The coloring of the panel is using the "panelbg" which is defined by the DashBoard Aura theme and can't be changed. I took a look at the code generated to produce the panel by importing it into a custom panel, but the color is applied to each element in the panel, so you would need to edit the color of each canvas, abs, button and label manually to achieve a global color change.
Alun Fryer
Technical Marketing Lead, Hyperconverged Solutions
