Thanks again for help on this. We now have completed our PHP class to control the router and online.
Tim Free
Chief Engineer
WCAV-TV
Charlottesville United States
Sent: 05-24-2023 17:47
Subject: Ultrix GVG Native Protocol Commands
Yes that worked.
Had to adjust the checksum routine in my php class and I can now route using the protocol.
Now to finish the rest.
Tim Free
Chief Engineer
WCAV-TV
Sent: 05-24-2023 14:41
Oops the Checksum is wrong.
it should be this. I tested it and it is workign on my system.
01 4E 30 54 49 09 30 30 37 35 09 30 30 35 39 33 39 04
Mike Pomerleau
Sent: 05-23-2023 10:48
I adjusted my code to account for the 0 based GVG native and created the same command you came up with, router did not switch and received N0TI0075005938 in Hercules. Not seeing anything in the logs.
Tim Free
Cjief Engineer
WCAV-TV
Sent: 05-22-2023 18:45
Hi Tim,
Arent router protocols fun!
Your formatting looks right. But I think you are rouing Source 91 to Destination 119.
GVG native is 0 based so input 90 to output 118 is actually 89 to 117
89 in HEX is 0059 which is 30 30 35 39 in ascii
117 in HEX is 0075 which is 30 30 37 35 in Asci
01 4E 30 54 49 09 30 30 37 35 09 30 30 35 39. check sum is 38 (33 38)
01 4E 30 54 49 09 30 30 37 35 09 30 30 35 39 33 38 04 should be the complete comand.
Unfortunately I dont have a frame to test it on right now, but I think I am close.
Let me know if this works!
Mike Pomerleau
