Hi Mike,
Had some issues first when the license was locked. at the end a reboot helped and also a local instance of dashboard in stead of VPN.
I have a connection now, i see on the RX part some commands already:
68:{"slot":0,"payload":{"oid":"0x212","value":"ENET 1"},"type":"value"}, most time and network updates.
but i try to put the payload in but nothing is happening. if i see it correctly, the value needs to be 0 or 1 depending on activate or deactivate, and slot and input depending on what i need.
if i want port 1 slot 1 enabled i need to do:
104:{"payload":{"element":false,"oid":"params.framesync.ports.1.license","value":1},"slot":1,"type":"value"},
and if i want it disabled i need to do:
104:{"payload":{"element":false,"oid":"params.framesync.ports.1.license","value":0},"slot":1,"type":"value"},
is this a correct way still?
Kind Regards,
Rick
Sent: 06-27-2024 17:10
Subject: Ultrix Ultrisync remote controlable
Hi Rick,
one of my colegues, Milos, found the solution.
Send text string below to port 5254 of the ultrix frame.
104:{"payload":{"element":false,"oid":"params.framesync.ports.0.license","value":1},"slot":0,"type":"value"},
You can adjust the Slot and Port numbers to match the framesync you want to activate/deactivate.
Hope this helps!
Mike Pomerleau
Sent: 06-27-2024 10:04
Hi Rick,
This is a great question.
Give me a couple days to look into this. I have some ideas.
Mike Pomerleau
