Correct it loads the pixels in from Top Left. Then you would only be able to move within the raster. It is not loading or able to draw pixels outside of the raster.
if the image is larger then screen you will want to pull it out via FTP on a computer and then edit the image into the Raster Size and Position you would like.
Sent: 10-15-2025 11:01
Subject: Unable to change media store XY-position on any image
the image is larger than the raster screen. so guessing thats out of the question too then. so only smaller can be repositioned?
Andrew Grieves
Technical studio director
create and craft
Sent: 10-15-2025 10:53
the XY position can only be used on images that are smaller than the raster of the screen. If the image is screen size then there is no adjusting it with the those properties.
