Hi Mike,
I have found the issue. the issue was with the port of my unmanaged switcher to which i had my router and My PC connected. i have changed the ports and now the Dashboard is connecting to the Router . Thank you
jaiprakash naidu Chief Manager-Broadcast Operations
Broadcast Manager
TV18 Broadcast Ltd
Chennai India
Sent: 01-07-2024 13:09
Subject: Unable to connect to my 144x144 NK router from Dashboard
You are running an NK-IPS control system to connect to your NK144 router. can you make sure that the Tbus connection from the IPS to the router is properly connected?
Also did this work with previous versions of Dashboard and is now no longer working with version 9.7?
Mike Pomerleau
