Thanks for letting us know you resolved it.
Sent: 06-19-2025 13:40
Subject: Unable to Locate Assigned IP Address for Ultrix Power via Dashboard
Yes, you are right.
I connected my pc to the device using the cable, and I was able to successfully detect the Ultripower IP and edit the network settings
Really appreciate your help!
Sharon Li
Sent: 06-19-2025 13:01
could be that your network switches are blocking the broadcast traffic.
since you have other devices that should show up I would expect then that it is network config related. Is you computer in a similar network range or local switch as those devices? could be that you are connected via a VLAN or WiFi that the switch will not allow that traffic to cross over too.
Sent: 06-19-2025 12:21
Hello Les,
Thanks for your reply. I tried using Walkabout and refreshed it as you suggested, but no device showed up. Do you know why that might be?
Sharon Li
Sent: 06-19-2025 12:09
you can use Walkabout to find it:
You can even Edit the network settings from here then reboot the device with the changes.
This should help resolve your issues.
